21602 Discussions
compilation report in Quartus
Can anyone tell me how can I display the details of compilation report?
After done write the VHDL code and compile it, I want to display the report in terms of area and maximum frequency. How can I do that..help me please
Many thanks
--- Quote Start ---
Many thanks
--- Quote End ---
a short overview of the resource uitilization you can found by selection of the "Flow summary" page.
For timing info's you have to open the "TimeQuest Timing Analyzer" section in the compilation report.
Kind regards
GPK
Hi pletz,
Can I observe the latency and throughput also? thanks for reply..
--- Quote Start ---
Hi pletz,
--- Quote End ---
what did you mean with latencey and throughput ? The clock speed of your design or the
number of clock cycles your processing need ?
Kind regards
GPK
Hi pletz,
I want both of them..thanks for reply
--- Quote Start ---
Hi pletz,
--- Quote End ---
the results of the timing analysis shows you how fast your design could run. Important
is that you specify reasonable timing constraints.
The number of clock cycles for your processing must be calculated by yourself.
Kind regards
GPK
Hi pletz,
How about the power consumption?..Thanks for reply
--- Quote Start ---
Hi pletz,
--- Quote End ---
HI,
I know there is a power calculator build-in in Quartus, but I have no experience
using it.
Kind regards
GPK
Hi pletz,
power calculator?..Okay, I try study on that. Many thanks pletz =)
