compiler problem
Hello
I had a C++ code running well on NIOS II IDE software. Then I upgraded the software and then the code was stucked in a loop of my code. I did not change anything in the code of course.
So I just changed the optimization of the compiler settings ("optimize more") to "None" and now it works again.
How is it possible?
thank you
NIOS forum is probably a better resource, and i think the problem may be related to embedded coding practices. global variables need to be volatile etc.
