21611 Discussions
cyclone ep1c20 flash
I use the ALTERA Cyclone Development Kit ep1c20F400C7
Question 1:how to see the result of the program or how I load my application in Flash
Question 2: How to view & delete the contents of the flash
Please I am starting please MORE detail and thankx in advance:)
If you are designing system based on Nios II processor, you can use Nios II EDS to see results and in same application you will find flash programmer through which you can load your application in flash, also you can view flash content (in memory window) when you run Nios II application in debug mode
The official Dev Kit name is nios ii development kit or nios development board cyclone edition. The reference and user manual tells to use the NIOS SDK shell to program the flash.
I only schedule a small application based on 7 segment display and then I program my fpga is using Quartus and now I want to see the result on the card and I press the sw0 and SW8 and release sw0 but not output the display 2 is displayed by default I believe there is another program it runs by default
help me
