21602 Discussions
de2 115 board audio codec i2c address
hello everyone,
im trying to access audio codec and i faced a problem. what is the slave address of this audio codec?
i looked into the demostration files for getting an idea about i2c bus. i saw these lines:
//=========start===========
6'd1 : begin
SD = I2C_DATA;
SDO = 0;
end
6'd2 : SCLK = 0;
//======SLAVE ADDR=========
6'd3 : SDO = SD[23];
6'd4 : SDO = SD[22];
6'd5 : SDO = SD[21];
6'd6 : SDO = SD[20];
6'd7 : SDO = SD[19];
6'd8 : SDO = SD[18];
6'd9 : SDO = SD[17];
6'd10 : SDO = SD[16];
6'd11 : SDO = 1'b1;//ACK
//========SUB ADDR==========
6'd12 : begin
SDO = SD[15];
ACK1 = I2C_SDAT;
6'd13 : SDO = SD[14];
6'd14 : SDO = SD[13];
6'd15 : SDO = SD[12];
6'd16 : SDO = SD[11];
6'd17 : SDO = SD[10];
6'd18 : SDO = SD[9];
6'd19 : SDO = SD[8];
going so far..
etc. but, i couldn't understand difference between sub addr and slave addr.
the sub address may be register address. but, what should be slave address?
i need your help
thanks,
can
Hi can,
I need to implement ADC using Codec on DE2-115 board. Can you help me out with some example.
thanks,
vrv
can't you get the device address from the datasheet of the audio codec WM8731 ?
Hello canokcelik,
I'm studying the audio codec and if you take a look in another part of this code (clock_500.v block) you will observe that this address is fixed:
wire [23:0]DATA={8'h34,DATA_A};
I dont know what 34h means, I just know that is the slave address. 35h means another address, but I forgot what it means... =/
Sub address is the address of the registers, as you said, for example:
ROM[0] = 16'h0c00; //power down => (0000 110)(0 0000 0000) it means register 6 (R6), take a look in the datasheet.
sub_addr binary settings
ROM[1] = 16'h0ec2; //master => (0000 111)(0 1100 0010) it means register 7 (R7)
I hope I have helped you and sorry for the bad english.
Hello everyone, sorry for delay.
i have solved the problem. The slave address is 0x34, as viniciuslagrota indicated in his reply.
viniciuslagrota: h prefix in h34 means that following number's radix is hexadecimal. so it is converted to "00011010" in your example because of 8'h34(In here, 8 indicates that following number must has 8 bits). you can send me an email about what you are doing now. may be, i can help you about somethink.
