21585 Discussions
dedicated clock pins and IOs
Is it in any way possible to use a dedicated clock pin as an output? I have a Cyclone III and want to output a clock signal from pin 150 which is a dedicated clock.
Thank you
try it and quartus will scream if it does not like it
using Quartus is a good suggestion, it has all of the legality checks built in. the Pin Connection Guidelines and/or Schematic Review Worksheets are also a good resource:
http://www.altera.com/literature/lit-dpcg.jsp
http://www.altera.com/download/board-layout-test/schematic-review-ws/srw-index.jsp
