21615 Discussions
delay error in Model_sim
Hi. I have a problem in simulation.
I made a code and It has no error while compiling.
but When i simulated the code in model sim..
It has one delay time. so the output was pushed one pulse.
What's the problem. and how can I fix it?
below is the simulation error image.. below site you can see image.( I can't upload my image... in here!! and if image is so small , then
download and see.. then you can see big image.
Thanks!
http://image.kilho.net/?pk=982125
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY comp is
PORT(
a,b : IN std_logic_vector(1 downto 0);
agb, alb, aeb : OUT std_logic);
END comp;
ARCHITECTURE arc of comp is
SIGNAL result : std_logic_vector(2 downto 0);
BEGIN
PROCESS(a,b)
BEGIN
IF a<b then
result <= "001";
ELSIF a=b then
result <= "010";
ELSIF a>b then
result <= "100";
ELSE
result <= "000";
END IF;
agb <= result(2);
aeb <= result(1);
alb <= result(0);
END PROCESS;
END arc;
It is because the process is sensitive to changes in (a) or (b) only. Try add result to sensitivity list. Or put assignments for aeb,alb,agb outside process.
