I'd like to graphically disable a part of my project, i.e. select a group of blocks and "comment" them, so that they are still there, though not active. Does anyone know if this is possible? I'm using Q11. Thank you!Link Copied
I'm not sure it's possible, but if you disconnect your groups' outputs from the rest of the design, then they will be optimized away by the synthesizer.
