Programmable Devices
21602 Discussions
enable differential mode on alt_iobuf??
I have a project based on and Arria 10 SoC development board which using FMC ports (LVDS IO Standard). I have a bidrectional pin which is the "io" port in an alt_iobuf instance.
The project synthesizes fully, but fails on the fitting, giving the error " can't on open-drain option for differential io pin".
I have looked up the solution and everywhere says to enable differential mode on the IO buffer, but nowhere says how to enable it?. Here is the current instance:
alt_iobuf IOBUFF_scl (
.i(1'b0),
.oe(scl_oen),
.io(scl), //bidirectional pin
.o(scl_c_normal)
How do you enable differential mode?
Dáire
Not sure what you want to achieve. If it's bidirectional respectively multi-drop LVDS, review application note for BLVDS (bus LVDS).
