I have a project based on and Arria 10 SoC development board which using FMC ports (LVDS IO Standard). I have a bidrectional pin which is the "io" port in an alt_iobuf instance.
The project synthesizes fully, but fails on the fitting, giving the error " can't on open-drain option for differential io pin". I have looked up the solution and everywhere says to enable differential mode on the IO buffer, but nowhere says how to enable it?. Here is the current instance: alt_iobuf IOBUFF_scl ( .i(1'b0), .oe(scl_oen), .io(scl), //bidirectional pin .o(scl_c_normal) ); How do you enable differential mode? DáireLink Copied
Not sure what you want to achieve. If it's bidirectional respectively multi-drop LVDS, review application note for BLVDS (bus LVDS).
