My code is as followed:signal cnt_clks : natural range 0 to 300;
cnt_clks <= conv_integer(unsigned(time)) * 25;
process(clk_50, reset)
begin
if reset = '1' then
enc_delay <= (others => '0');
enc_delay_in <= '0';
elsif rising_edge(clk_50) then
enc_delay(cnt_clks downto 0) <= enc_delay((cnt_clks -1) downto 0) & enc_in(1);
enc_delay_in <= enc_delay(cnt_clks);
end if;
end process;
Modelsim compiles it with no problem. Quartus shows the 'Expression is not constant' error (I'm using Quartus 15). How can I overcome that? I tried defining cnt_clks as Integer, no luck. Roy
what is definition for enc_delay. Hope it declared properly for at least 300 bits long. The size should be greater then maximum value of {cnt_clks} 300.
it seems shift register that should shift for random number bits. How do you think synthesis tool could implent your code?- Mark as New
It doesnt matter how enc_delay is calculated - quartus only supports slicing an array with a constant. And in your case your code implies slicing a variable number of bits out of an array, which is not possible with VHDL.
You could rewrite your assignment with a for loop that goes through each bit of enc_delay and either shifts it or keeps it depending on the value of the index compared to cnt_clks.
Do you really have a signal called "time" ? I'm surprised this doesn't conflict with the standard TIME type.- Mark as New
--- Quote Start --- Do you really have a signal called "time" ? I'm surprised this doesn't conflict with the standard TIME type. --- Quote End --- time is not a reserved keyword, nor are any type names. So you can use it to confuse yourself thoroughly (and it works because VHDL is all context driven) signal time : std_logic; signal std_logic : integer range 0 to 153; signal integer : real range -0.1 to 100.66;
