21611 Discussions
error in compiling Quartus 9
hi
im using Quartus 9 and I designed a 4 bit counter, im sure my designation is true and I followed step by step on training movies to compile my project
but i have these errors.
I can see these vhdl files in my computer
I thing there is a problem in Quartus not in my designation.
please help me
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 9.0 Build 235 06/17/2009 Service Pack 2 SJ Web Edition
Info: Processing started: Tue Nov 22 18:45:39 2011
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off hi -c hi
Info: Found 1 design units, including 1 entities, in source file hi.bdf
Info: Found entity 1: hi
Info: Elaborating entity "hi" for the top level hierarchy
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/std/standard.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/altera/altera_internal_syn.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/altera/altera_syn_attributes.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/std/textio_vhdl93.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/ieee/std_1164.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/ieee/numeric_std.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/ieee/numeric_bit.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/ieee/math_real.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/ieee/timing_p.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/ieee/timing_b.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/ieee/prmtvs_p.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/ieee/prmtvs_b.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/synopsys/syn_arit.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/synopsys/syn_unsi.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/synopsys/syn_sign.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/synopsys/syn_attr.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/synopsys/syn_misc.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/mentor/mgc_arit.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/mentor/mgc_qsim.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/altera/maxplus2.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/altera/megacore.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/altera/altera_primitives_components.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/altera_mf/altera_mf_components.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/lpm/lpm_pack.vhd"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/APEX20KE_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/APEX20K_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/APEXII_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/FLEX10KE_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/FLEX6000_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/MAX_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/MAXII_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/ARRIAGX_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/STRATIX_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/STRATIXII_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/STRATIXIII_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/STRATIXIV_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/CYCLONE_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/CYCLONEII_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/wysiwyg/CYCLONEIII_COMPONENTS.VHD"
Error (10660): Can't find standard library file "c:/altera/90sp2/quartus/libraries/vhdl/altera/altera_europa_support_lib.vhd"
Error: Quartus II Analysis & Synthesis was unsuccessful. 40 errors, 0 warnings
Error: Peak virtual memory: 210 megabytes
Error: Processing ended: Tue Nov 22 18:45:40 2011
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 42 errors, 0 warnings
are those files in the directory they are supposed to be?
have to tried re-installing?
have you tried a newer version of quartus?
yes the vhdl codes of them are in the file
i use Quartus 9 and for a simple circuit that has just and , or I recieve those errors , I didnt have such problems same days ago
