21615 Discussions
error in pin planner
hello all,
i got one error in pin planner that is Error (176172): Can't place node "hsync_n" -- node is a differential I/O node.
with this post i am attached .Qsf file. i dont know why this error comes and how to resolve it.
i also check 'IO_MAXIMUM_TOGGLE_RATE "0MHz"' settings that was not removed. so plz give me some solution about this error.
http://www.alteraforum.com/forum/showthread.php?t=46925 (http://www.alteraforum.com/forum/showthread.php?t=46925
As per my response to your other thread open with the same question...
A quick look at the .qsf you posted shows a conflict between the 'hsync_p' & 'hsync_n' signals. One is 1.8V, the other 2.5V.
I think you should be generating hsync as a differential signal. However, your qsf shows different single ended I/O standards for each half of the pair.
If you still need help let me know.
Happy New Year,
Alex
