I want to implement a project on Cyclone IV GX FPGA which produce customs interrupts which are sent to the kernel through PCIe using MSI. From the side of the linux driver pci_enable_msi() is called and return with success, indicating that my card is capable of MSI. I also call request_irq() and through /proc/interrupts file I can see that my driver is successfully waiting for MSI interrupts. My question is : How can I use Qsys to implement a mechanism that will produce interrupts that the driver will be able to recognize? What components and with what connections should I use? Thanks in Advance AntonisLink Copied
--- Quote Start --- Hello, My question is : How can I use Qsys to implement a mechanism that will produce interrupts that the driver will be able to recognize? What components and with what connections should I use? --- Quote End --- 1) Read the PCIe user guide. 2) Look at some example designs. 3) Modify and example design to do what you want. There are quite a few threads about the PCIe interface here (try the IP section). Nial.
I have read the PCIe user guide and I found that the signal app_msi_req produces the interrupts to pci express.
Also I check the followed registers that are responsible for generating msi interrupts: 1. Set the MSI Enable at bit[0] of MSI Control Status register, this bit is mapped to bit[16] of configuration space register offset 0x50. 2. Set the Interrupt Disable at bit[10] of Command Register at configuration space offset register 0x4 to disable legacy interrupt. 3. Set the Bus Master at bit[2] of Command Register at configuration space offset register 0x4 to enable the ability to generate MSI message. Every 1 sec I enable the app_msi_req inorder to see every 1 sec interrupts in my driver. app _msi_tc and app_msi_num assigned to zero. Still I can not see interrupts in my driver. The interrupt handler is not called. I would like to ask: 1) What should I check more? Do I miss something important? 2) How can I simulate this desing to check if I get app_msi_ack=1 ?? 3) Should I change more signals? Thanks in Advance!- Mark as New
I have asserted RxmIrq and app_msi_req signals (Signals that are responsible for Interrupts as it's said in the IP compiler user Guide) every 100 cylces.
In simulation, I saw that it is asserted app_int_ack every time that RxmIrq and app_msi_req are asserted. BUT NOT app_msi_ack is turn to 1. I guess that this is happend because of the configuration of the testbence ( INTx is enabled instead of MSI). Nevertheless I can not see interrupts from the side of the software. Any advices ? Do I miss something important? How can I set the simulation from INT to msi mode? Thanks you.- Mark as New
Also I want to ask : why there are some signals that are terminated.??
some signals are : .aer_msi_num (5'b00000), // (terminated) .app_int_sts (1'b0), // (terminated) .app_msi_num (5'b00000), // (terminated) .app_msi_req (1'b0), // (terminated) .app_msi_tc (3'b000), // (terminated) is there any reason that are terminated?- Mark as New
I'm sorry Toniss, I was being facetious as I thought you were looking for someone to do what you wanted without putting
any work in, this is obviously not the case. Good luck, there are a lot of gaps in the PCIe implementation/ tools / documentation. Nial.
