Programmable Devices
21588 Discussions
fifoed avalon uart custom baudrate
Hi all,
Does anyone know how can I proceed to use fifoed avalon uart in a non standard baud rate (500 000 bauds).
I have yet added 500000 at line 81 of fifoed_avalon_uart_hw.tcl : set_parameter_property baud ALLOWED_RANGES {5000000 2000000 921600 500000 460800 230400 115200 57600 38400 31250 28800 19200 14400 9600 4800 2400 1200 300}
It appears in a component GUI but i supposed this is not the only modification that we need?
I think you'll find the baudrates in that list are validated via other files. So, I think you'll need to do (a little) more.
I've successfully added a custom baudrate to the standard Nios UART peripheral in this way. For that, as well as the '.tcl' file, I had to modify the 'class.ptf', 'em_uart.pl' & 'em_uart_qsys.pm' files - although each only to add the custom baudrate as an simple integer value. From memory, Qsys refused to generate until these changes were made.
Cheers,
Alex
