21607 Discussions
floating license showing no check out
we successfully connect to the license server and checkout out licenses
however there is no checkouts are showing up in the logs.
[root@finnegan /home/admin]# ps -ef | grep altera
flexlm 869 868 0 10:01:40 ? 0:01 alterad -T finnegan 9.5 3 -c /home/flexlm/altera/SOL10/license.dat -p --lmgrd_s
flexlm 868 1 0 10:01:40 pts/1 0:01 /home/flexlm/bin/v9.50/lmgrd -2 -p -c /home/flexlm/altera/SOL10/license.dat -l
Can any one help? we just move this altera flexlm licensing server to Solaris 10.
Is there any other way to check the checkouts?
Thanks a lot for helping in advance
Best regards
Jenny
If you are compiling for a device which is only supported in Altera's subscription version you should see a check out in the log when you run the fitter. You might not see a checkout event for synth only, or if you are compiling for a Web edition supported device.
The other method of checking status is to run: lmutit lmstat -a -c port@server
this will return the current status of the server.
I am running a server on solaris 9, and I am seeing all checkouts, however I am creating a log by piping the output of lmgrd to a file >& rather than with the -l option
Thanks for the information,
We increase the timestamp value seems to fixed the pb
find:lmgrd [ -app ] [ -c license_file ] [ -t timeout_interval ] [ -l logfile ]
[ -s timestamp_interval ] [ -2 -p ] [ -v ] [ -x lmdown ] [ -x lmremove ]
