Programmable Devices
21616 Discussions
generate clock with pll
I'd like to know how to generate a clock with the PLL to obtain two frequencies 8kHz and 256khz and simulate with ModelSim altera in cpld.thanks
I don't think you can use an Altera PLL with that low a frequency.
You could use a PLL locked to, and generating, a higher frequency and divide down to 8KHz and 256KHz with logic.
It depends what your input clock frequency is.
FPGA PLLs can't generate that low frequencies, check the respective device handbooks for the available PLL frequency range. Also CPLDs have no PLL hardware.
A clock divider is the usual solution for low frequencies.
ok thank you but how can I do to solve this problem I am beginner and I want a document that may help
What is the frequency of your input clock?
8KHz is a nice divide of 256KHz (/32) so this is just 8 divide by 2s.
A divide by 2 is a simple flip flop with the inverse of the output as the input.
If your can choose an input frequency that is power of 2 multiple of 256KHz then it should be easy
I have not a specific input frequency, but I have to choose a frequency that I realized the two frequencies that I want.
So how should we do with the details please and thanks
Have a look at
http://www.fpga-faq.com/faq_pages/0019_divide_clock_by_n_point_5.htm
It should help
Google "clock divider fpga" for more info!
ok but what I see is only a description
What is it exactly you are after?
Do you need help using Quartus/Altera FPGAs?
Do you need more info on clock dividers? The link I posted does have some Verilog code and I thought it gave a good introduction.
Do you want someone to code the VHDL/verilog etc for you? It would be far better to read up on the subject and do the design and code it yourself. You'd learn a lot more and it might be fun :)
Sorry to be a bit blunt but I am not sure what you are after.
Thank you, this is a way to learn .But I have a project or I do PRODUCING A synchronous clock generator using Altera CPLD max3, ie from an input clock I must have output frequencies 8kHz output and 256 kHz and I think I can utiliset altpll of Quartus (megawizard) but I also need the VHDL code and testbench to simulate in ModelSim-Altera.
in fact it was what I do.thanks
