generate .h file
User1580871742356367
I'm trying to generate .h file for Arria 10 HPS/Soc project and it didn't work, see below.
I've tried commands
$ sopc-create-header-files hps_0.sopcinfo
zangman
You are using a windows command prompt which won't work since the sopc-create-header-files is a shell script.
Instead you should use a cygwin shell to generate the header files. You also need to have sopc-create-header-files on the path. Watch this video.
Yes, it stuck because I'm using19.4. Will install Ubuntu.
AnilErinch_A_Intel
Hi ,
Hope your issue is resolved after installing a recommended version of Ubuntu.
Please let us know if any further support is required on the same issue.
Thanks and Regards
Anil
