21597 Discussions
get problem while compile the qts_pcie_sfp demo of C10GFP
BXia
The board is Cyclone 10 GX Development kit,  I download the Kit Collateral (zip), and compile the qts_pcie_sfp demo with Quartus Pro 17.1 per its required, I didn't do any change to the demo, but I get error, you can check the attached compile_error.txt for the error detail.
Could you help to check what's the problem and how to fix it?
Deshi_Intel
Attached is the compilation successful QAR file
Deshi_Intel
The issue was the QSYS file is not sync correctly in default project.
So, i reopen all the QSYS design, resync and regenerate it again. After that, Quartus project can be compiled successfully.
dlim
BXia
Hi dlim,
Thanks very much for your new project.
I compiled this new one without the previous error now, but have a new error as shown in the attached picture and document.
Could you help to check again?
Deshi_Intel
Attached is successful compilation screenshot without Quartus internal error
Deshi_Intel
I didn't face Quartus internal error during fitter compilation.
Your Quartus internal error seems to be complaining it can't find C10 device database file.
  1. Did you installed full Quartus v17.1 Pro including the Cyclone 10 device database file ?
  2. Else you can try to reinstall or Quartus again to see if it's corrupted or something
dlim
