Programmable Devices
21615 Discussions
global clock buffer problems
Dear all,
Here is my code for multiplexer. I used a secondary global clock buffer (BUFGS) in the code.
library ieee;
use ieee.std_logic_1164.all;
entity clock_mux is
port (DATA, SEL : in std_logic;
SLOW_CLOCK, FAST_CLOCK : in std_logic;
DOUT : out std_logic);
end clock_mux;
architecture XILINX of clock_mux is
signal CLOCK : std_logic;
signal CLOCK_GBUF : std_logic;
component BUFGS
port (I : in std_logic;
O : out std_logic);
end component;
begin
Clock_MUX : process (SEL)
begin
if (SEL = '1') then
CLOCK<= FAST_CLOCK;
else
CLOCK<= SLOW_CLOCK;
end if;
end process;
GBUF_FOR_MUX_CLOCK : BUFGS
port map (I=> CLOCK, O=> CLOCK_GBUF);
Data_Path : process (CLOCK_GBUF, DATA)
begin
if (CLOCK_GBUF'event and CLOCK_GBUF = '1') then
DOUT<= DATA;
end if;
end process;
end XILINX;
But the error occurred after compile the code:
Error: Node instance "GBUF_FOR_MUX_CLOCK" instantiates undefined entity "BUFGS"
As i know, we need to instantiate the BUFGS by using the Insert Pads command. However, i do not clear about the Insert Pads command. Can anyone help me please.
Many thanks
Dear DT, this forum is about Altera FPGAs, not Xilinx FPGAs.
Dear rbugalho,
It is different using BUFGS in ALTERA and XILINX?
Many thanks for your response
As far as I know BUFGS doesn't exist in Quartus, so yes it is different.
Dear Daixiwen,
That mean Quartus does not support for global clock buffer. Right?
Thanks for response
No I just said Quartus doesn't support BUFGS. I don't know what a BUFGS exactly is, but in Altera FPGAs buffers are used automatically when a clock is declared global. What you are looking for seems to be a very Xilinx specific technology and you probably won't find an answer here.
Dear Daixiwen,
I understand that.. Thank you very much
dt_conan,
try to declare this library:
library UNISIM; use UNISIM.VComponents.all;
Dear Szymo,
Did you mean insert your code above into my existing code?
Thanks for response
Right. It contains definitions of clk buffers (among others).
Dear Szymo,
Thank you very much. I will try it.
Dear Szymo,
I has try insert your given code above. But, this error occur:
Error (10481): VHDL Use Clause error at clock_mux.vhd(4): design library "UNISIM" does not contain primary unit "VComponents"
It is I miss anything?..Many thanks
dr_conan,
the "equivalent" of BUFGS in Quartus would be GLOBAL.
http://quartushelp.altera.com/9.1/mergedprojects/hdl/prim/prim_file_global.htm
That said, nowadays both Quartus and ISE will (mostly) promote signals to global lines as needed.
Anyway, using logic to implement clock multiplexers is somethings best avoided, as it has high delay and possible glitches.
In Altera FPGAs, use the ALT_CLKCTRL primitive instead.
