Dear all,
Here is my code for multiplexer. I used a secondary global clock buffer (BUFGS) in the code. --------------------------------------------------------------------- library ieee; use ieee.std_logic_1164.all; entity clock_mux is port (DATA, SEL : in std_logic; SLOW_CLOCK, FAST_CLOCK : in std_logic; DOUT : out std_logic); end clock_mux; architecture XILINX of clock_mux is signal CLOCK : std_logic; signal CLOCK_GBUF : std_logic; component BUFGS port (I : in std_logic; O : out std_logic); end component; begin Clock_MUX : process (SEL) begin if (SEL = '1') then CLOCK<= FAST_CLOCK; else CLOCK<= SLOW_CLOCK; end if; end process; GBUF_FOR_MUX_CLOCK : BUFGS port map (I=> CLOCK, O=> CLOCK_GBUF); Data_Path : process (CLOCK_GBUF, DATA) begin if (CLOCK_GBUF'event and CLOCK_GBUF = '1') then DOUT<= DATA; end if; end process; end XILINX; ----------------------------------------------------------------------- But the error occurred after compile the code: Error: Node instance "GBUF_FOR_MUX_CLOCK" instantiates undefined entity "BUFGS" As i know, we need to instantiate the BUFGS by using the Insert Pads command. However, i do not clear about the Insert Pads command. Can anyone help me please. Many thanksLink Copied
Dear DT, this forum is about Altera FPGAs, not Xilinx FPGAs.
Dear rbugalho,
It is different using BUFGS in ALTERA and XILINX? Many thanks for your response- Mark as New
As far as I know BUFGS doesn't exist in Quartus, so yes it is different.
Dear Daixiwen,
That mean Quartus does not support for global clock buffer. Right? Thanks for response- Mark as New
No I just said Quartus doesn't support BUFGS. I don't know what a BUFGS exactly is, but in Altera FPGAs buffers are used automatically when a clock is declared global. What you are looking for seems to be a very Xilinx specific technology and you probably won't find an answer here.
Dear Daixiwen,
I understand that.. Thank you very much- Mark as New
dt_conan,
try to declare this library:library UNISIM;
use UNISIM.VComponents.all;
Dear Szymo,
Did you mean insert your code above into my existing code? Thanks for response- Mark as New
Right. It contains definitions of clk buffers (among others).
Dear Szymo,
Thank you very much. I will try it.- Mark as New
Dear Szymo,
I has try insert your given code above. But, this error occur: Error (10481): VHDL Use Clause error at clock_mux.vhd(4): design library "UNISIM" does not contain primary unit "VComponents" It is I miss anything?..Many thanks- Mark as New
dr_conan,
the "equivalent" of BUFGS in Quartus would be GLOBAL. http://quartushelp.altera.com/9.1/mergedprojects/hdl/prim/prim_file_global.htm That said, nowadays both Quartus and ISE will (mostly) promote signals to global lines as needed. Anyway, using logic to implement clock multiplexers is somethings best avoided, as it has high delay and possible glitches. In Altera FPGAs, use the ALT_CLKCTRL primitive instead.
