公告
21615 讨论
gxb2_cal_clk in SDI-receiver
名誉分销商 II
1,657 次查看
Hello
I use SD-SDI receiver in ArriaGX device. Global clock in project - 27MHz.
rx_sd_oversample_clk_in - 67.5 MHz
what calibration clock I must to connect to 'megafunction input "gxb2_cal_clk"
The same question for HD-SDI receiver.
rx_seral_refclk - 74.25 MHz
thank you
0 项奖励
3 回复数
名誉分销商 II
673 次查看
http://www.altera.com/literature/hb/agx/agx_52001.pdf
page 7:
cal_blk_clk Input Calibration clock for the transceiver
termination blocks. This clock supports
frequencies from 10 MHz to 125 MHz.
0 项奖励
名誉分销商 II
673 次查看
any value of frequencies from 10 to 125 MHz?
Are there any recomendetions, how to choose the value
0 项奖励
名誉分销商 II
673 次查看
in devices like Stratix IV GX, you need a calibration and reconfiguration clock. the overlap of the two ranges makes 50 MHz a common choice
0 项奖励
回复
