21585 Discussions
hello sir can u help me, i am displaying 3 digits using seven segment display, everything is done i got output(used verilog HDL code) but the problem is during power up it is reset to "000". previous values are not stored. so what is the solution
CShek1
Tricky
New Contributor II
FPGAs are volatile, so state is always lost on reset
CShek1
k thank you for reply, but what is the solution sir.,
Tricky
New Contributor II
What are you trying to do? Why do you need to retain state after power down?​
