Programmable Devices
21615 Discussions
how can we enable and disable the particular modules we need in verilog?
i need to enable a particular module when some condition is satisfied and each module is selected on particular condition...i have written different modules now and i need to write a top module to connect all these modules under it...can you guys help me to solve this issue?....i tried to instantiate it in case statement but it s showing error...
Use a Generate statement:
generate
if (someparam == 1) begin
module module_i (
ports
end
endgenerate
i tried it and could not get the code compiled...showing error...
Don't expect further help if you don't provide more information about the error
this is the sample code i hav written...please check for an error ...
module arithmetic20(A,B,S,out);
input A,B;
input [1:0]S;
output out;
generate
if(S==2'b00)
begin
and1 a1(A,B,out);
end
endgenerate
generate
if(S==2'b01)
begin
or1 o1(A,B,out);
end
endgenerate
generate
if(S==2'b10)
begin
xor1 x1(A,B,out);
end
endgenerate
generate
if(S==2'b11)
begin
nor1 n1(A,B,out);
end
endgenerate
endmodule
module and1(A,B,out);
input A,B;
output out;
wire out;
assign out=A&B;
endmodule
module or1(A,B,out);
input A,B;
output out;
wire out;
assign out=(A|B);
endmodule
module xor1(A,B,out);
input A,B;
output out;
wire out;
assign out=(A^B);
endmodule
module nor1(A,B,out);
input A,B;
output out;
wire out;
assign out=(~(A|B));
endmodule
Generates will only work with static parameters define at synthesis time. So this won't work for you. What you could do is simply:
assign out = (S == 2'b00) ? A&B :
(S == 2'b01) ? A| B :
(S == 2'b10) ? A^B : ~(A|B );
what you are saying is correct...the above is just an example...i have to make a control unit for alu...in alu i have done adder,multiplication and logical modules written separately in gate level...
