i need to enable a particular module when some condition is satisfied and each module is selected on particular condition...i have written different modules now and i need to write a top module to connect all these modules under it...can you guys help me to solve this issue?....i tried to instantiate it in case statement but it s showing error...
Use a Generate statement:
generate if (someparam == 1) begin module module_i ( ports ); end endgenerate- Mark as New
i tried it and could not get the code compiled...showing error...
Don't expect further help if you don't provide more information about the error
this is the sample code i hav written...please check for an error ...
module arithmetic20(A,B,S,out); input A,B; input [1:0]S; output out; generate if(S==2'b00) begin and1 a1(A,B,out); end endgenerate generate if(S==2'b01) begin or1 o1(A,B,out); end endgenerate generate if(S==2'b10) begin xor1 x1(A,B,out); end endgenerate generate if(S==2'b11) begin nor1 n1(A,B,out); end endgenerate endmodule module and1(A,B,out); input A,B; output out; wire out; assign out=A&B; endmodule module or1(A,B,out); input A,B; output out; wire out; assign out=(A|B); endmodule module xor1(A,B,out); input A,B; output out; wire out; assign out=(A^B); endmodule module nor1(A,B,out); input A,B; output out; wire out; assign out=(~(A|B)); endmodule- Mark as New
Generates will only work with static parameters define at synthesis time. So this won't work for you. What you could do is simply:
assign out = (S == 2'b00) ? A&B : (S == 2'b01) ? A| B : (S == 2'b10) ? A^B : ~(A|B );- Mark as New
what you are saying is correct...the above is just an example...i have to make a control unit for alu...in alu i have done adder,multiplication and logical modules written separately in gate level...
