*** Fatal Error: Access Violation at 0X547ABC76
Module: quartus.exe Stack Trace: 0x7bc75: WIZMAN_PLUG_IN_LST_MANAGER::set_wizard_info_struct + 0xc35 0x7cff9: WIZMAN_PLUG_IN_LST_MANAGER::extract_wizard_info_from_lst + 0x569 0x7d9eb: WIZMAN_PLUG_IN_LST_MANAGER::read_lst_info_from_lib_paths + 0xbb 0x85a7e: wizman_read_lst_files + 0x6e 0x6e748: GEDQ_INSERT_SYMBOL_DIALOG::GEDQ_INSERT_SYMBOL_DIALOG + 0xc98 0x6f79c: GEDQ_INSERT_SYMBOL_MODE::insert_symbol + 0x5c 0xa8d4e: GEDQ_VIEW::on_symbol_mode_action + 0x1e 0x10c74a: QMetaObject::activate + 0x3ba 0xc6bd: QAction::activate + 0xcd 0x3a613a: QToolButton::nextCheckState + 0x1a 0x304878: QButtonGroup::setId + 0xa68 0x304bc9: QAbstractButton::mouseReleaseEvent + 0x49 End-trace Quartus II 32-bit Version 13.1.0 Build 162 10/23/2013 SJ Web EditionLink Copied
Delete the DB and incremental_DB folders and try again.
