21604 Discussions
how to extend delay
How do i create delay for the output in the waveform?
Currently i'm having half a cycle delay, i want to increase it to 1 cycle.
(i have circled the area in the picture attatched)
And also, how do i make the period of the output to be 3 times the size of 1 clock period?
(i have also attatched the expected outcome)
This is what i have till now...
library ieee;
use ieee.std_logic_1164.all;
ENTITY traffic_light IS
PORT(sensor : IN std_logic;
clock : IN std_logic;
red_light : OUT std_logic;
green_light : OUT std_logic;
yellow_light : OUT std_logic);
END traffic_light;
ARCHITECTURE simple OF traffic_light IS
TYPE t_state is (red, green, yellow);
SIGNAL present_state, next_state : t_state;
BEGIN
PROCESS(present_state, sensor)
BEGIN
CASE present_state IS
WHEN green =>
next_state <= yellow;
red_light <= '0';
green_light <= '1';
yellow_light <= '0';
WHEN red =>
red_light <= '1';
green_light <= '0';
IF (sensor = '1') THEN
next_state <= green;
ELSE
next_state <= red;
END IF;
WHEN yellow =>
red_light <= '0';
green_light <= '0';
yellow_light <= '1';
next_state <= red;
END CASE;
END PROCESS;
PROCESS
BEGIN
WAIT UNTIL clock'EVENT and clock = '1';
present_state <= next_state;
END PROCESS;
END simple;
Please help!!
Usually, the way to extend signals is to add counters, and then inside the state machine wait till that counter gets to the correct value.
--- Quote Start ---
--- Quote End ---
So does that mean i have to add counter to extend the output delay? and also the period of the output waveform? i'm sorry don't quite get what u mean... :confused:
Yes add a counter, then in your state machine do something like this:
WHEN red => red_light <= '1'; green_light <= '0'; yellow_light <= '0'; IF (sensor = '1') and counter = 3 THEN next_state <= green; ELSE next_state <= red;
i guess i need to declare the "counter" at the top right? thanks i'll try it out
