hi everyone
if i add an ip from the library in Qsys, how should i use it in Eclipse? is there an pdf or reference design to teach me how to use it?(like read/write, setup interrupt) and how can i find the APIs of the ip?Link Copied
it depends which IP you use. Try google the name of the ip or try the documentation button inside the opened qsys-ip...- Mark as New
Almost every IP core comes with some documentation, which can be more or less complete.
If it's an IP from Altera or if the IP has been designed as a Qsys component, usually you have the HAL driver or, at least a register map to access it through IOWR/IORD. If you need to integrate a generic IP (i.e. from opencores.org) you may need to add a wrapper to interface it to Avalon bus, create a new custom device in Qsys and write the APIs yourself.
Topic Options
