Programmable Devices
21604 Discussions
how to interface an ADC with 3 wire SPI (bidir SDIO) to Qsys ?
I need to connect the SPI port of an AD9266 ADC to a Cyclone 5 SoC. This is a 3 wires SPI : clock, CS and bidirectional data (SDIO).
Can I have some hints ? I see that the QSYS SPI module supports only 4 wire SPI. Do I have to write my own vhdl module and
then interface it to QSYS ? Considering that this is probably a common problem, does someone has an example ?
Franco
Franco,
The cyclone HPS SPI won't allow you to properly access the AD9266.
It implements the SPI standard with two uni-directional bus "wire": MOSI and MISO and neitehr of them can be set bi-directional.
If you are ready to go through a lot of pain, may be the QSPI could be used.
In a single lane configuration, the QSPI the same SPI 2 uni-directional bus "wire".
But in dual or quad lane, the bus becomes 2 ror 4 bi-directional "wire" for the data transfers and only for the data.
You'll need go through a lot of hoop and loops trying to spoof the QSPi protocol to
FPGA is one safe way to go...
BUT!!!
Yes there is a but! :-)
Using the SPI, you can put an open collector or open drain chip + a pull-up resistor between the SPI MOSI line and the ADC data line.
The you connect the ADC data line directly to the SPI MISO.
I think that should do the job if you properly program the SPI controller & send all 1's when reading.
It might not be possible to make the QSPI controller behave like a generic bidirectional SPI controller since it's intended for QSPI flash devices and not I/O like an ADC. I do not believe Qsys comes with a bidirectional slave controller but it shouldn't be much effort to create one from scratch especially if you build it just for the ADC you have in mind.
