21611 Discussions
how to program the .elf file into the flash
use jtag to download the .elf into the ssram and run, use the command:
nios2-download -g *.elf , succeed.
but if i want to download the .elf file into the flash and run , use this command , system generates message:
downloaded 62kb in 1.4s(44.2kb/s)
verifying 0c000000 (0%)
verify failed between address 0xc000000 and 0x c00f54b
leaving target processor paused.
i have to use nios2 IDE. import the project, tools/flash programming/. this is too troublesome.
who can tell me how to download the .elf file into the flash using command line method. thanks.
I don't have the DE2. But as far as I know, you need to use the "flash programmer" to download elf or sof files to flash via JTAG.
In your sopc system, a cfi flash controller is needed as well.
You should confirm which component has the address 0xc000000
