Programmable Devices
21611 Discussions
how to start working with sopc and nios
hi.
i am just beginner.........i am going to start work with nios.
i dont know from where i do start??
can any body give the step for starting.
I recommend you buy the NEEK (Nios Embedded Evaluation Kit) made by Altera and follow the step by step guide on developing your first Nios II platform using the free SOPC builder that comes with Quartus (also included in the kit).
Assuming you have a good understanding of embedded micro controller systems this should help explain how all the elements fit together to deliver your first functioning platform.
This is the route i took and to be perfectly honest there were no questions left unanswered by the time i had completed the step through guides.
Good luck, and enjoy!
first of all thankyou for reply.............
i have gone through cyclone ii kit................also run example project
but how to add custom peripheral is Avalon bus is not clear .can you help on this ??????
Hi - no problem
check this thread
http://www.alteraforum.com/forum/showthread.php?t=4088&highlight=custom+sopc+component
FYI: the search in this forum tends to yield pretty relevant results, I searched for "custom sopc component" to find that. It's Worth giving it a shot next time as you'll get your solutions to common problems/questions faster than having to wait for a reply here.
cheers
