Programmable Devices
21611 Discussions
how to use another vhdl file's function?
bin2bcd7 is not in the scope
and
error at H1:bin2bcd7 port map (X"0001" => bin_in, bcd7_out => HEX0);
bin2bcd7.vhd
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity bin2bcd7 is
Port ( bin_in : in STD_LOGIC_VECTOR (3 downto 0);
bcd7_out : out STD_LOGIC_VECTOR (6 downto 0));
end bin2bcd7;
architecture Behavioral of bin2bcd7 is
top file - Lab2.vhd
library IEEE;
entity Lab2 is
Port (
HEX0 : OUT STD_LOGIC_VECTOR(6 DOWNTO 0));
end Lab2;
architecture Behavioral of Lab2 is
begin
bin2bcd7(X"0001",HEX0);
end Behavioral;
or
library IEEE;
entity Lab2 is
Port (
end Lab2;
component bin2bcd7
port (bin_in : in STD_LOGIC;
end component;
begin
end Behavioral;
I didn't understand your problem or question, but I think this lineH1:bin2bcd7 port map (X"0001" => bin_in, bcd7_out => HEX0); should beH1:bin2bcd7 port map (bin_in => X"0001", bcd7_out => HEX0);
Error (10500): VHDL syntax error at Lab2.vhd(19) near text "=>"; expecting ")", or ","
i just want to input "0001" into bin_in and output from bcd7_out to HEX0 to display a digit number on board
bin2bcd7.vhd
library IEEE;
entity bin2bcd7 is
end bin2bcd7;
begin
with bin_in Select
bcd7_out<=
"1111001"when"0001",
"0100100"when"0010",
"0110000"when"0011",
"0011001"when"0100",
"0010010"when"0101",
"0000010"when"0110",
"1111000"when"0111",
"0000000"when"1000",
"0010000"when"1001",
"0001000"when"1010",
"0000011"when"1011",
"1000110"when"1100",
"0100001"when"1101",
"0000110"when"1110",
"0001110"when"1111",
"1000000"when others;
end Behavioral;
I don't see any mistake in the port map, so I don't get why you have this error. Is the coma there between the two port associations?
And from the code in bin2bcd, the input port bin_in is 4 bits wide and not 4 hexadecimal digits wide, so in your portmap you should use "0001" and not X"0001"
if use "0001", it will get error
after changed to
https://skydrive.live.com/redir?resid=e0ed7271c68be47c!300
it become better, less error, got new error
You will learn soon that "less error" doesn't always mean better ;)
It should work without the 'X', but from what I see your component declaration in the architecture is wrong, you have defined bin_in and bcd7_out as std_logic signals instead of std_logic_vector.
Success, it really works, it can display one in 7 segment LED
