bin2bcd7 is not in the scope
and error at H1:bin2bcd7 port map (X"0001" => bin_in, bcd7_out => HEX0); bin2bcd7.vhd library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity bin2bcd7 is Port ( bin_in : in STD_LOGIC_VECTOR (3 downto 0); bcd7_out : out STD_LOGIC_VECTOR (6 downto 0)); end bin2bcd7; architecture Behavioral of bin2bcd7 is ... top file - Lab2.vhd library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity Lab2 is Port ( HEX0 : OUT STD_LOGIC_VECTOR(6 DOWNTO 0)); end Lab2; architecture Behavioral of Lab2 is begin bin2bcd7(X"0001",HEX0); end Behavioral; or library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity Lab2 is Port ( HEX0 : OUT STD_LOGIC_VECTOR(6 DOWNTO 0)); end Lab2; architecture Behavioral of Lab2 is component bin2bcd7 port (bin_in : in STD_LOGIC; bcd7_out : out STD_LOGIC ); end component; begin H1:bin2bcd7 port map (X"0001" => bin_in, bcd7_out => HEX0); end Behavioral;Link Copied
I didn't understand your problem or question, but I think this lineH1:bin2bcd7 port map (X"0001" => bin_in, bcd7_out => HEX0);
should beH1:bin2bcd7 port map (bin_in => X"0001", bcd7_out => HEX0);
Error (10500): VHDL syntax error at Lab2.vhd(19) near text "=>"; expecting ")", or ","
i just want to input "0001" into bin_in and output from bcd7_out to HEX0 to display a digit number on board bin2bcd7.vhd library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity bin2bcd7 is Port ( bin_in : in STD_LOGIC_VECTOR (3 downto 0); bcd7_out : out STD_LOGIC_VECTOR (6 downto 0)); end bin2bcd7; architecture Behavioral of bin2bcd7 is begin with bin_in Select bcd7_out<= "1111001"when"0001", "0100100"when"0010", "0110000"when"0011", "0011001"when"0100", "0010010"when"0101", "0000010"when"0110", "1111000"when"0111", "0000000"when"1000", "0010000"when"1001", "0001000"when"1010", "0000011"when"1011", "1000110"when"1100", "0100001"when"1101", "0000110"when"1110", "0001110"when"1111", "1000000"when others; end Behavioral;- Mark as New
I don't see any mistake in the port map, so I don't get why you have this error. Is the coma there between the two port associations?
And from the code in bin2bcd, the input port bin_in is 4 bits wide and not 4 hexadecimal digits wide, so in your portmap you should use "0001" and not X"0001"- Mark as New
if use "0001", it will get error
after changed to H1:bin2bcd7 port map (bin_in => X"0001", bcd7_out => HEX0); https://skydrive.live.com/redir?resid=e0ed7271c68be47c!300 it become better, less error, got new error- Mark as New
You will learn soon that "less error" doesn't always mean better ;)
It should work without the 'X', but from what I see your component declaration in the architecture is wrong, you have defined bin_in and bcd7_out as std_logic signals instead of std_logic_vector.- Mark as New
Success, it really works, it can display one in 7 segment LED
