21618 Discussions
hyperterminal communication with CPLD
I'm new to the CPLD world and verilog programming. I found a uart core that I'm trying to use to communicate with hyper terminal. At the moment all I want to do is send a "hello world" string to the computer via the RS232. I've created the top module, but I'm stuck how to really use it to accomplish what I want to do. Below are the code for the two files, any help will be greatly appreciated it.
module mainMod( CLK, // The master clock for this module RxD, // Incoming serial line TxD, // Outgoing serial line Transmit, // Signal to transmit (strobe) Received, // Indicated that a byte has been received. RxD_DATA, // Byte received TxD_DATA, // Byte to transmit is_TxD // Low when transmit line is idle. ); input CLK; // The master clock for this module input RxD; // Outgoing serial line output TxD; // Incoming serial line input Transmit; // Signal to transmit output Received; // Indicated that a byte has been received. output RxD_DATA; input TxD_DATA; output is_TxD; // Low when transmit line is idle. uart U1 (CLK, , RxD, TxD, Transmit, TxD_DATA, Received, RxD_DATA, , is_TxD , ); endmodule
module uart( input clk, // The master clock for this module input rst, // Synchronous reset. input rx, // Incoming serial line output tx, // Outgoing serial line input transmit, // Signal to transmit input tx_byte, // Byte to transmit output received, // Indicated that a byte has been received. output rx_byte, // Byte received output is_receiving, // Low when receive line is idle. output is_transmitting, // Low when transmit line is idle. output recv_error // Indicates error in receiving packet. ); parameter CLOCK_DIVIDE = 13; // clock rate (1Mhz) / (baud rate (19200) * 4) // States for the receiving state machine. // These are just constants, not parameters to override. parameter RX_IDLE = 0; parameter RX_CHECK_START = 1; parameter RX_READ_BITS = 2; parameter RX_CHECK_STOP = 3; parameter RX_DELAY_RESTART = 4; parameter RX_ERROR = 5; parameter RX_RECEIVED = 6; // States for the transmitting state machine. // Constants - do not override. parameter TX_IDLE = 0; parameter TX_SENDING = 1; parameter TX_DELAY_RESTART = 2; reg rx_clk_divider = CLOCK_DIVIDE; reg tx_clk_divider = CLOCK_DIVIDE; reg recv_state = RX_IDLE; reg rx_countdown; reg rx_bits_remaining; reg rx_data; reg tx_out = 1'b1; reg tx_state = TX_IDLE; reg tx_countdown; reg tx_bits_remaining; reg tx_data; assign received = recv_state == RX_RECEIVED; assign recv_error = recv_state == RX_ERROR; assign is_receiving = recv_state != RX_IDLE; assign rx_byte = rx_data; assign tx = tx_out; assign is_transmitting = tx_state != TX_IDLE; always @(posedge clk) begin if (rst) begin recv_state = RX_IDLE; tx_state = TX_IDLE; end // The clk_divider counter counts down from // the CLOCK_DIVIDE constant. Whenever it // reaches 0, 1/16 of the bit period has elapsed. // Countdown timers for the receiving and transmitting // state machines are decremented. rx_clk_divider = rx_clk_divider - 1; if (!rx_clk_divider) begin rx_clk_divider = CLOCK_DIVIDE; rx_countdown = rx_countdown - 1; end tx_clk_divider = tx_clk_divider - 1; if (!tx_clk_divider) begin tx_clk_divider = CLOCK_DIVIDE; tx_countdown = tx_countdown - 1; end // Receive state machine case (recv_state) RX_IDLE: begin // A low pulse on the receive line indicates the // start of data. if (!rx) begin // Wait half the period - should resume in the // middle of this first pulse. rx_clk_divider = CLOCK_DIVIDE; rx_countdown = 2; recv_state = RX_CHECK_START; end end RX_CHECK_START: begin if (!rx_countdown) begin // Check the pulse is still there if (!rx) begin // Pulse still there - good // Wait the bit period to resume half-way // through the first bit. rx_countdown = 4; rx_bits_remaining = 8; recv_state = RX_READ_BITS; end else begin // Pulse lasted less than half the period - // not a valid transmission. recv_state = RX_ERROR; end end end RX_READ_BITS: begin if (!rx_countdown) begin // Should be half-way through a bit pulse here. // Read this bit in, wait for the next if we // have more to get. rx_data = {rx, rx_data}; rx_countdown = 4; rx_bits_remaining = rx_bits_remaining - 1; recv_state = rx_bits_remaining ? RX_READ_BITS : RX_CHECK_STOP; end end RX_CHECK_STOP: begin if (!rx_countdown) begin // Should resume half-way through the stop bit // This should be high - if not, reject the // transmission and signal an error. recv_state = rx ? RX_RECEIVED : RX_ERROR; end end RX_DELAY_RESTART: begin // Waits a set number of cycles before accepting // another transmission. recv_state = rx_countdown ? RX_DELAY_RESTART : RX_IDLE; end RX_ERROR: begin // There was an error receiving. // Raises the recv_error flag for one clock // cycle while in this state and then waits // 2 bit periods before accepting another // transmission. rx_countdown = 8; recv_state = RX_DELAY_RESTART; end RX_RECEIVED: begin // Successfully received a byte. // Raises the received flag for one clock // cycle while in this state. recv_state = RX_IDLE; end endcase // Transmit state machine case (tx_state) TX_IDLE: begin if (transmit) begin // If the transmit flag is raised in the idle // state, start transmitting the current content // of the tx_byte input. tx_data = tx_byte; // Send the initial, low pulse of 1 bit period // to signal the start, followed by the data tx_clk_divider = CLOCK_DIVIDE; tx_countdown = 4; tx_out = 0; tx_bits_remaining = 8; tx_state = TX_SENDING; end end TX_SENDING: begin if (!tx_countdown) begin if (tx_bits_remaining) begin tx_bits_remaining = tx_bits_remaining - 1; tx_out = tx_data; tx_data = {1'b0, tx_data}; tx_countdown = 4; tx_state = TX_SENDING; end else begin // Set delay to send out 2 stop bits. tx_out = 1; tx_countdown = 8; tx_state = TX_DELAY_RESTART; end end end TX_DELAY_RESTART: begin // Wait until tx_countdown reaches the end before // we send another transmission. This covers the // "stop bit" delay. tx_state = tx_countdown ? TX_DELAY_RESTART : TX_IDLE; end endcase end endmodule // Documented Verilog UART // Copyright (C) 2010 Timothy Goddard (tim@goddard.net.nz) // Distributed under the MIT licence.
