Programmable Devices
20750 Discussions
image read in vhdl
i want to read an image (or preferably a matrix of size 8x8) pixel by pixel in one clock cycle(if rising edge then read one pixel in 2nd rising edge 2nd pixel)....thanks in advance
This code is pretty much the same as before. There are still several problems:
d(n) gets a value every 128 clocks, and takes 8192 clocks to fill. Also- d(n) is always the old value of temp_approx because you registered it.
In integer arithmatic, 1/2 = 0. So your temp_approx value will be 2*(n+2).
You should see all of this in your simulation waveforms.
