i recently try to instal the altera complet design ,but i was in frot of this error
"you successfully installed the quartus II software but did not install any device ;if you want install device support ,you must also run the 10.1 device _windows.exe executable which you can finf on the download center of the altera website " can you help me where i can find theese devices ??Link Copied
You should probably install V12.1sp1 instead, but if you really need V10.1, here is the link
https://www.altera.com/download/software/quartus-ii-se/10.1
