Programmable Devices
21592 Discussions
integer data type
hello everyone,
I need help here.Below is my vhdl code:
LIBRARY ieee;
USE ieee.ALL;
ENTITY haar IS
PORT (
clock : IN bit;
clk : IN bit;
-- Inputs
in1 : IN integer RANGE -127 TO 127;
in2 : IN integer RANGE -127 TO 127;
in3 : IN integer RANGE -127 TO 127;
in4 : IN integer RANGE -127 TO 127;
in5 : IN integer RANGE -127 TO 127;
in6 : IN integer RANGE -127 TO 127;
in7 : IN integer RANGE -127 TO 127;
in8 : IN integer RANGE -127 TO 127;
--Outputs
out1 : OUT integer RANGE -127 TO 127;
out2 : OUT integer RANGE -127 TO 127;
out3 : OUT integer RANGE -127 TO 127;
out4 : OUT integer RANGE -127 TO 127;
out5 : OUT integer RANGE -127 TO 127;
out6 : OUT integer RANGE -127 TO 127;
out7 : OUT integer RANGE -127 TO 127;
out8 : OUT integer RANGE -127 TO 127
END haar;
ARCHITECTURE haar OF haar IS
begin
PROCESS(clk)
BEGIN
IF clk'EVENT AND clk = '1' THEN
output <= input;
END IF;
END PROCESS;
END haar;
My question is why when i create the waveform file for the code, the pins is not same as the expected pins? I get the input pins like below:
in1[0]
in1[1]
in1[2]....in1[7]
But, that is not i want.Suppose the input is like:
in1, in2, in3,....in8.
Can anyone help me solve this problem?.
Each of your ports translates to 8 bits in Hardware terms.
I wonder what
output <= input;
means as these names are not declared or did you just say it for short...
the code above is for short..Actually i obtain the based on the pipelined architecture that i has been designed.It consist of 3 stage and include 3 basic component.I try to troubleshoot the coding by simulate stage by stage,but the problem occurs is same..why?
Thanks for reply.
You don't have any problem thus far. You are asking in1 to be range -127 ~ 127 i.e. 8 bits. so is in2 and so on...
Sorry, i don't understand what u said..It is mean that the input pins i get;
in1[0], in1[1], in1[2]....in1[7] is correct?
--- Quote Start ---
in1[0]
in1[1]
in1[2]....in1[7][/QUOte]
where do you get like this?
I get the pins at the vector waveform file..in the node finder.
Thanks for reply.
--- Quote Start ---
--- Quote End ---
I see, but I don't know why. You can rearrange them by using the grouping feature.
Thanks FvM..can i ask one question, what actually the function of buffer in vhdl code?
