io pin stuck
User1580871742356367
We are running into an issue with Arria 10 SoC FPGA (10AS066N2).
We have two LED enable signals on pin J26 and D25 on bank 2K. It is the same bank that HPS DDR4 resides.
1. we have no problem to turn on and off both LED with FPGA only project(no HPS)
2. however we can only control one of the LED enabled from pin D25 with the project that has both HPS and FPGA.
Any ideas. Thank you.
AnilErinch_A_Intel
Hi ,
Please use the below link for getting a list of available working projects and use them as reference for building your own projects.
https://rocketboards.org/foswiki/Projects/SoC
Thanks and Regards
Anil
