21602 Discussions
is it possible internal signal to be in process sensitiv list (vhdl)
hello
i am using ciclone 2. i do vhdl module and i want to ask is it possible itnernal signal to be part of sensitive list of process:
process (clock, second, ten_7segment_sign_vector , q_2_HOURS_vect_signal, ten_hours_signal_vector , two_hours_vect_signal ) begin --if ((ten_7segment_sign_vector = "0100") and (q_2_HOURS_vect_signal = "1001") and (hours_10_signal_vect = "0011" ) and (hours_2_signal_vect = "0010") ) then --if ((ten_7segment_sign_vector = "1001") and (q_2_HOURS_vect_signal = "0101")) then if (second'event and second = '0') then if ((ten_7segment_sign_vector = "1001") and (q_2_HOURS_vect_signal = "0101")) then if ( (ten_hours_signal_vector = "0011") and (two_hours_vect_signal = "0010") ) then -- rst2_signal <= '1'; --resert10hours <= '1'; rst10_signal <= '1'; --rst10hours <= '1'; reset_10_hours <= '1' ; reset_2_hour <= '1'; reset_2_hours <= '1'; else reset_2_hours <= '0'; reset_10_hours <= '0' ; rst10_signal <= '1'; reset_2_hour <= '1'; end if; else reset_10_hours <= '0'; -- rst2_signal <= '0'; --resert10hours <= '0'; rst10_signal <= '0'; --rst10hours <= '0'; reset_2_hour <= '0'; reset_2_hours <= '0'; end if ; end if ; end process;
where second is internal signal used as clock
Yes, but what you are doing is very bad. Use the clock as a clock ONLY. dont make your own clocks unless they are the output of a PLL.
Generate enable signals instead.
