Programmable Devices
公告
21615 讨论
it's weird that my state machine got into a wrong state
名誉分销商 II
1,503 次查看
I'm writing some verilog code to communicate with my usb controller, the simulation result is good , but it seems that my fpga hangs after running 1~2 houres. At last I display the state on LEDs, to my astonishment, when fpga hangs the leds output is not defined(no led flashes).
I'm using Quartus 9.0 for Linux, Terasic DE0 board (cyclon III EP3C16F484C6N )
Can someone give me some hints? Thanks!
My code are as follows:
localparam IDEL = 8'b00000001,
STATE1 = 8'b00000010,
STATE2 = 8'b00000100,
STATE3 = 8'b00001000,
STATE4 = 8'b00010000,
STOPTX = 8'b00100000,
STOPTX2= 8'b01000000;
always @(posedge clk or negedge reset_n)
begin
if(!reset_n)
begin
state_next<=IDEL;
end
else
begin
case(state_next)
idel:
begin
if(!fifo_empty)
state_next<=STATE1;
pktend_next<=1'b1;
end
state1:
begin
fifo_addr_reg<=2'b10;
state_next<=STATE2;
end
state2:
begin
if(full!=1'b0) //usb buffer not full
begin
if(!fifo_empty)//output fifo is not empty
begin
slwr_next<=1'b0;
data_next<=_fifo_[rdptr];
last_out<=_fifo_[rdptr];
state_next<=STATE3;
end
else
state_next<=IDEL;
end
else
state_next<=IDEL;
end
state3:
begin
usb_count<=usb_count+1;
slwr_next<=1'b1;//write into usb
state_next<=STATE4;
rdptr<=(rdptr+1)%FIFO_LEN;
end
state4:
begin
if(!fifo_empty)
begin
state_next<=STATE2;
end
else
state_next<=IDEL;
end
stoptx:
begin
pktend_next<=1'b0;
state_next<=STOPTX2;
end
stoptx2:
begin
pktend_next<=1'b1;
state_next<=IDEL;
end
default:
state_next<=idel;
endcase
end
end
0 项奖励
1 回复
名誉分销商 II
482 次查看
The relation of LED outputs and states of your state machine isn't shown in your post, but I simply assume, that the state machine is caught in an illegal state. If you read the Quartus Software Handbook chapter about state machines thorougly, you'll notice, that
default: state_next<=idel; doesn't work for illegal states. You have define safe state machine encoding to handle illegal states, e.g. by a synthesis attribute.
reg state_next /* synthesis syn_encoding = "safe" */
Generally, there are two possibly reasons, why a state machine can reach an illegal state (= an undefined bit coding of the state variable):
1. The input clock has glitches or temporary short periods, that cause a timing violation in the state machine logic
2. An input signal to the state machine is changing unrelated to the state machine clock and cause a timing violation. All unrelated input signals must be synchronized before being processed in the state machine.
To understand, why unrelated input signals can cause illegal states, you should consider, that the input signal is fed through combinational logic to the state variable registers, but each bit of the state machine is treated individually. Due to a setup or hold time violation, individual bits can react inconsistently on the event (one bit "sees" the event, the other doesn't).
0 项奖励
回复
