Hello, everyone. I'd like to ask
I now ask. JIC file, each in its structure has a CRC check, where can I find or provide a document
thank you
Unfortunately we do not have the file to provide the information related to CRC checl.
do you mean there is no CRC code similar to bin file in JIC? So, is it similar to the data that can prove the uniqueness of the JIC file?
JIC is ASCII code which is readable by user.
Hi
Do you have this document, or know the name of this document, I will try to find it
thank
I make a mistake on mentioning JIC is user readable. Actually JIC is a binary file which is only readable by Quartus. We do not release any document or guide on how to check the file.
Same with RPD file where it is a binary file. We are not able to released how the format structure as it is confidential.
Hello
what else can identify JIC and read it as data
thanks
Unfortunately there is no way to read the file as it is a binary data.
hi ,
Thank you very much for your patience in answering the questions. I hope you can give me a suggestion now. Is there any way to identify the uniqueness of JIC files.
May I know what type of uniqueness are you looking for?
hi
I want the data that can prove the uniqueness of this JIC file, just like CRC validation code, can prove its uniqueness
thanks
Each generation of the JIC file will varies. Not sure if this uniqueness is sufficient?
hi
Because I want to pass the last generated JIC file to others through this unique "data", and then ensure that this JIC file is the last one I generated and transferred to him.This' data 'can be seen.
thanks
Unfortunately there is no way to determine the jic file as it is only binary file which is used to program into the flash.
Let me know if you have further queries or feel free to create new forum case if you have any new issue.
