21611 Discussions
license for questa not available doesn't work outside home
lucasvdh
When going outside my home i got this message for my license. This license worked fine at my home however as soon as I got outside it gave me the following error code: "Unable to checkout a viewer license necessary for use of the Questa Intel Starter FPGA Edition graphical user interface.
Vsim is closing." How would i be able to fix this? i put my license in the discription
FvM
that's not your license.
Your license is bound to network adapter MAC, most likely the chosen network adapter is not connected when you are out of home, e.g. if it's inside a docking station. Solution get a license bound to an internal network adapter, e.g. WiFi.
FvM
sstrell
Yes, and then point to the actual license file with the LM_LICENSE_FILE environment variable.
AR_A_Intel
You may regenerate license.dat file in SSLC https://licensing.intel.com/, Refer the steps here: Guide to generate license file.
Link: https://www.intel.com/content/www/us/en/docs/programmable/683472/23-1/viewing-your-new-licenses-and-generating.html
AR_A_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
