21595 Discussions
lpm_add_sub - signed
Sorry for maybe a silly question but my brain stopped working.
I add 2 9-bits signed numbers. The result is also 9-bits. what do i do with the overflow bit?
To illustrate:
logic signed [8:0] data_a;
logic signed [8:0] data_b;
logic signed [8:0] result_temp;
logic signed [9:0] result ;
logic overflow;
adder_module U1 (.clock(clk), .dataa(data_a), .datab(data_b), .overflow(overflow), .result(result_temp));
assign result = overflow + result_temp;
or I have to do this:
assign result = {overflow, result_temp};
Interested especially when deal with negative numbers. And if my result signal is much larger than [8:0] result_temp.
I've tried simulate in Modelsim and even if my "result_temp" is negative I always get positive "result".
