I' m using the Quartus 9.1(SP2) and NIos 9.1 IDE. I wrote v files and C code for speech recognition system.V files were compiled correctly & also the nios IDE build the project.When I try to run the project and download it to the board, it displayed as follows.
Pausing target processor: OK Reading System ID at address 0x000000D8: verified Initializing CPU cache (if present) OK Downloading 02000000 ( 0%) Downloading 02010000 (87%) Downloaded 74KB in 1.2s (61.6KB/s) Verifying 02000000 ( 0%) Verifying 02010000 (87%) Verified OK Starting processor at address 0x020001C4 and displayed in the upper bar <terminated>nios Nios II Hardware configuration[ Nios II Hardware] nios II download Can u help me regarding this...... Thank U...Link Copied
It seems everything is fine. What exacty is your problem? The software was correctly downloaded and the processor was started.
If you are expecting a console, check that your SOPC system has a JTAG Uart compenent, and that the IDE is configured to launch a nios 2 terminal after the download.
