I'm using Modelsim 6.6d starter edition.
I've tried searching the forums here and the "web", but sadly all I found was a bunch of people saying to add Veriuser = "\eda\mentor\modelsim\convert_hex2ver.dll" in the modelsim.ini file or to remove it. I did both, added and removed the modelsim.ini file from my project folder, modified both the project one and the altera install folder's .ini for modelsim. Nothing works. It just keeps asking for "\eda\mentor\modelsim\convert_hex2ver.dll" because it can't find it. I'm not very sure what to do. I could simulate perfectly yesterday with an other project but now I can't with this new one. And it's doing next to nothing, too. Only a clock division module... ?!? Any ideas would be greatly appreciated. <<<*EDIT*<<< The exact full errors are: # ** Error: (vsim-3193) Load of "\eda\mentor\modelsim\convert_hex2ver.dll" failed: File not found.# ** Error: (vsim-PLI-3002) Failed to load PLI object file "\eda\mentor\modelsim\convert_hex2ver.dll". >>>*EDIT*>>>Link Copied
*bump*
I'm pretty sure I can't be the only one with this or a similar error. Even Altera's knowledge base had a page on something similar... Any ideas, anyone ? Thanks!- Mark as New
can you post example code to reproduce the problem?
Here is the problem module...
`timescale 1ns/1ns
module VGA_1
CLOCK_50, KEY,
VGA_CLK, VGA_R, VGA_G, VGA_B, VGA_HS, VGA_VS, VGA_BLANK_N, VGA_SYNC_N
input CLOCK_50;
input KEY;
wire CLOCK_50;
wire KEY;
output VGA_CLK;
output VGA_R, VGA_B, VGA_G;
output VGA_HS, VGA_VS, VGA_BLANK_N, VGA_SYNC_N;
wire VGA_CLK;
reg VGA_R = 8'd0;
reg VGA_B = 8'd0;
reg VGA_G = 8'd0;
reg VGA_HS = 1'b1;
reg VGA_VS = 1'b1;
wire VGA_BLANK_N;
reg VGA_SYNC_N = 1'b1;
wire rst;
assign rst = ~KEY;
// 25 MHz clock generation
reg clk_25M_cnt = 1'b0;
reg clk_25M = 1'b0;
assign VGA_CLK = clk_25M;
always @ (posedge CLOCK_50 or posedge rst)
begin
if(rst)
begin
clk_25M_cnt <= 1'b0;
clk_25M <= 1'b0;
end
else
begin
if(clk_25M_cnt)
begin
clk_25M <= ~clk_25M;
end
else
begin
clk_25M_cnt <= 1'b1;
end
end
end
// Color output generation
reg vga_state = 2'd0;
begin
if(rst)
begin
VGA_R <= 8'd1;
VGA_G <= 8'd0;
VGA_B <= 8'd0;
end
else
begin
if((VGA_R == 8'd0) || (VGA_R == 8'd255))
begin
VGA_R <= 8'd0;
if((VGA_G == 8'd0) || (VGA_G == 8'd255))
begin
VGA_G <= 8'd0;
if((VGA_B == 8'd0) || (VGA_B == 8'd255))
begin
VGA_B <= 8'd0;
VGA_R <= VGA_R + 8'd1;
end
else
begin
VGA_B <= VGA_B + 8'd1;
end
end
else
begin
VGA_G <= VGA_G + 8'd1;
end
end
else
begin
end
case (vga_state)
2'd0:begin
vga_state <= vga_state + 2'd1;
end
2'd1:begin
end
2'd2:begin
end
2'd3:begin
end
default:begin
vga_state <= 2'd0;
end
endcase
end
end
// Blanking signal generation
assign VGA_BLANK_N = (vga_blanking_h && vga_blanking_v);
// Sync signal generation for horizontal
reg vga_disp_cnt_h = 0;
reg vga_blanking_h;
// Horizontal counter
begin
if(rst)
begin
vga_disp_cnt_h <= 0;
end
else
begin
if(vga_disp_cnt_h == 1600) // 800 pixels
begin
end
else
begin
vga_disp_cnt_h <= vga_disp_cnt_h + 12'd1;
end
end
end
// Horizontal sync
begin
if(rst)
begin
VGA_HS <= 1'b1;
vga_blanking_h <= 1'b1;
VGA_SYNC_N <= 1'b1;
end
else
begin
// Front porch (16 pixels)
if(vga_disp_cnt_h >= 1568) // 784 pixels
begin
VGA_HS <= 1'b1;
vga_blanking_h <= 1'b0;
VGA_SYNC_N <= 1'b1;
end
// Horizontal sync (96 pixels)
else if(vga_disp_cnt_h >= 1376) // 688 pixels
begin
VGA_HS <= 1'b0;
VGA_SYNC_N <= 1'b1;
end
// Back porch (48 pixels)
else if(vga_disp_cnt_h >= 1280) // 640 pixels
begin
VGA_HS <= 1'b1;
VGA_SYNC_N <= 1'b1;
end
// Pixel dipsplay time (640 pixels)
else if(vga_disp_cnt_h >= 0) // 0 pixels
begin
VGA_HS <= 1'b1;
VGA_SYNC_N <= 1'b1;
end
end
end
// Sync signal generation for vertical
reg vga_disp_cnt_v = 0;
reg vga_blanking_v;
// Vertical counter
begin
if(rst)
begin
vga_disp_cnt_v <= 0;
end
else
begin
if(vga_disp_cnt_v == 525) // 525 lines
begin
end
else
begin
if(vga_disp_cnt_h == 1376)
begin
vga_disp_cnt_v <= vga_disp_cnt_v + 11'd1;
end
end
end
end
// Vertical sync
begin
if(rst)
begin
VGA_VS <= 1'b1;
vga_blanking_v <= 1'b1;
end
else
begin
// Front porch (10 lines)
if(vga_blanking_v >= 515) // 515 lines
begin
VGA_VS <= 1'b1;
vga_blanking_v <= 1'b0;
end
// Vertical sync (2 lines)
else if(vga_blanking_v >= 513) // 513 lines
begin
VGA_VS <= 1'b0;
end
// Back porch (33 lines)
else if(vga_blanking_v >= 480) // 480 lines
begin
VGA_VS <= 1'b1;
end
// Line dipsplay time (480 lines)
else if(vga_blanking_v >= 0) // 0 lines
begin
VGA_VS <= 1'b1;
end
end
end
endmodule
And the test bench for modelsim...
`timescale 1ns/1ns
module VGA_1_TB
reg clk = 1'b0;
reg KEY = 1'b0;
wire VGA_CLK;
wire VGA_R;
wire VGA_B;
wire VGA_G;
wire VGA_HS;
wire VGA_VS;
wire VGA_BLANK_N;
wire VGA_SYNC_N;
VGA_1 u (clk, key, VGA_CLK, VGA_R, VGA_G, VGA_B, VGA_HS, VGA_VS, VGA_BLANK_N, VGA_SYNC_N);
initial
begin
# 0 clk = 1'b0;
end
always
begin
# 5 clk = ~clk;
end
endmodule
Basically, get the error I mentioned whenever I try to simulate. And now, when I try to simulate another project that used to be working, I get an error too. All went to **** overnight. It worked one evening and didn't the next morning... without any changes to my computer, OS, etc. Any help is greatly appreciated !
*bump*
Hmm... still no ideas... :(
