21613 Discussions
max10 adc sample point
hi everyone:
i try to use max10 on chip adc to sample a image sensor output. the frequence is 1MHz.
i need to know when the max10 on chip adc switch from sample to the hold mode. in most adc, this is controlled by the CONVST signal.
acctually i can test the sample point by
1.applying a 1MHz sin signal to the adc input,
2.set the adc sample frequence to 1MHz, the adc will generate a valid signal every 1μs
3.put the sin signal and the adc valid signal on the oscilloscope
4.figure out the relationship between valid signal and the sample point.
the problem is :
1. i can not get the precise result
2. i can not make sure every max10 has the same result
but i still want to find the relationship between valid signal and the sample point on manual.
i use my method to test the sampe point on MAX10_10M08_Evaluation_Kit,
be careful, it is 5*clock_clk not 5* adc_pll_clock_clk!
the test condition is:
1. only use adc channel 1
2. 1MHz speed
as follows:
http://www.alteraforum.com/forum/attachment.php?attachmentid=12960&stc=1
http://www.alteraforum.com/forum/attachment.php?attachmentid=12961&stc=1
almost 15 months passed, i still do not find the answer.
i check the latest adc user guide(20171215), no describtion about the adc sampling point.
i some one find the answer, please share me.
thanks!
