21615 Discussions
modelsim10.0 can't Loading bytestream_pli.dll
# Loading ./..//submodules/bytestream_pli.dll# ** Error: (vsim-3193) Load of "./..//submodules/bytestream_pli.dll" failed: Bad DLL format.# ** Error: (vsim-PLI-3002) Failed to load PLI object file "./..//submodules/bytestream_pli.dll".
--- Quote Start ---
Bad DLL format.
--- Quote End ---
I recall seeing this on Windows 7 64-bit.
If you're not actually using the PLI interface, then edit setup_sim.tcl (or whatever your Modelsim script is) to remove bytestream_pli.dll from the vsim command line.
If you do need PLI, then you'll need to find the equivalent 64-bit DLL (perhaps it has 64 in its name).
Cheers,
Dave
