21602 Discussions
multiplayer in modelsim
hello
i write this code (parallel multiplayer) in modelsim
  • multi_player.vhd
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity MultTop is
port ( Multiplier: in std_logic_vector(3 downto 0);
Multiplicand: in std_logic_vector(3 downto 0);
Product: out std_logic_vector(7 downto 0);
Start: in std_logic;
Clk: in std_logic;
Done: out std_logic);
end MultTop;
architecture Behavioral of MultTop is
use work.mult_components.ALL; -- component declarations
-- internal signals to interconnect components
signal Mout,Qout: std_logic_vector (3 downto 0);
signal Dout,Aout: std_logic_vector (4 downto 0);
signal Load,Shift,AddA: std_logic ;
begin
C: Controller generic map (2) -- Controller with 2-bit counter
port map (Clk,Qout(0),Start,Load,Shift,AddA,Done);
A: AdderN generic map (4) -- 4-bit adder; 5-bit output includes carry
port map (Aout(3 downto 0),Mout,Dout);
M: RegN generic map (4) -- 4-bit Multiplicand register
port map (Multiplicand,Mout,Clk,Load,'0','0','0');
Q: RegN generic map (4) -- 4-bit Multiplier register
port map (Multiplier,Qout,Clk,Load,Shift,'0',Aout(0));
ACC: RegN generic map (5) -- 5-bit Accumulator register
port map (Dout,Aout,Clk,AddA,Shift,Load,'0');
Product <= Aout(3 downto 0) & Qout; -- 8-bit product
end Behavioral;
library IEEE;
entity RegN is generic (N: integer := 4);
port ( Din: in std_logic_vector(N-1 downto 0); --N-bit input
Dout: out std_logic_vector(N-1 downto 0); --N-bit output
Clk: in std_logic; --Clock (rising edge)
Load: in std_logic; --Load enable
Shift: in std_logic; --Shift enable
Clear: in std_logic; --Clear enable
SerIn: in std_logic );--Serial input
end RegN;
architecture Behavioral of RegN is
signal Dinternal: std_logic_vector(N-1 downto 0); -- Internal state
begin
process (Clk)
begin
if (rising_edge(Clk)) then
if (Clear = '1') then
Dinternal <= (others => '0'); -- Clear
elsif (Load = '1') then
Dinternal <= Din; -- Load
elsif (Shift = '1') then
Dinternal <= SerIn & Dinternal(N-1 downto 1); -- Shift
end if;
end if;
end process;
Dout <= Dinternal; -- Drive outputs**
end Behavioral;
library IEEE;
use IEEE.NUMERIC_STD.ALL;
entity AdderN is generic
(N: integer := 4);
port(
A: in std_logic_vector(N-1 downto 0); -- N bit Addend
B: in std_logic_vector(N-1 downto 0); -- N bit Augend
S: out std_logic_vector(N downto 0) ); -- N+1 bit result, includes carry
end AdderN;
architecture Behavioral of AdderN is
begin
S <= std_logic_vector(('0' & UNSIGNED(A)) + UNSIGNED( B );
end Behavioral;
library IEEE;
library work;
entity Controller is generic (N: integer := 2); -- # of counter bits
port (
Clk: in std_logic; -- Clock (use rising edge)
Q0: in std_logic; -- LSB of multiplier
Start: in std_logic; --Algorithm start pulse
Load: out std_logic; -- Load M,Q and Clear A
Shift: out std_logic; -- Shift A:Q
AddA: out std_logic; -- Load Adder output to A
Done: out std_logic -- Indicate end of algorithm
end Controller;
architecture Behavioral of Controller is
type states is (HaltS,InitS,QtempS,AddS,ShiftS);
signal state: states := HaltS;
signal CNT: unsigned(N-1 downto 0);
begin
-- Moore model outputs to control the datapath
Done <= '1' when state = HaltS else '0'; -- End of algorithm
Load <= '1' when state = InitS else '0'; -- Load M/Q, Clear A
AddA <= '1' when state = AddS else '0'; -- Load adder to A
Shift <= '1' when state = ShiftS else '0'; -- Shift A:Q
process(clk)
begin
if rising_edge(Clk) then
case state is when HaltS =>
if Start = '1' then -- Start pulse applied?
state <= InitS; -- Start the algorithm
end if;
when InitS => state <= QtempS; --Test Q0 at next clock**
when QtempS =>
if (Q0 = '1') then
state <= AddS; --Add if multiplier bit = 1
else
state <= ShiftS; -- Skip add if multiplier bit = 0
end if;
when AddS => state <= ShiftS; -- Shift after add
when ShiftS =>
if (CNT = 2*N - 1) then
state <= HaltS; -- Halt after 2^N iterations
else
state <= QtempS; -- Next iteration of algorithm: test Q0 **
end if;
end case;
end if;
end process;
process(Clk)
begin
if state = InitS then
CNT <= to_unsigned(0,N); -- Reset CNT in InitS state
elsif state = ShiftS then
CNT <= CNT + 1; -- Count in ShiftS state
end if;
end if;
end process;
--main process(test bench)--
Clk <= not Clk after 10 ns; -- 20ns period clock
process
begin
for i in 15 downto 0 loop -- 16 multiplier values
Multiplier <= std_logic_vector(to_unsigned(i,4));
for j in 15 downto 0 loop -- 16 multiplicand values
Multiplicand <= std_logic_vector(to_unsigned(j,4));
Start <= '0', '1' after 5 ns, '0' after 40 ns; -- 40 ns Start pulse
wait for 50 ns;
wait until Done = '1'; --Wait for completion of algorithm
assert (to_integer(UNSIGNED(Product)) = (i * j)) – Check Product
report "Incorrect product" severity NOTE;
wait for 50 ns;
end loop;
end loop;
end process;
--end main process(test bench)
end Behavioral;
  • mult_components.vhd package
library ieee;
use ieee.std_logic_1164.all;
package mult_components is component Controller -- Multiplier controller
port ( Clk: in std_logic;--rising edge clock
Q0: in std_logic; --LSB of multiplier
Start: in std_logic; --start algorithm
Load: out std_logic; --Load M,Q; Clear A
Shift: out std_logic; --Shift A:Q
AddA: out std_logic; --Adder -> A
Done: out std_logic ); --Algorithm completed
end component;
component AdderN -- N-bit adder, N+1 bit output
port( A,B: in std_logic_vector(N-1 downto 0);
end component;
component RegN -- N-bit register with load/shift/clear
Clk: in std_logic; --rising edge clock
SerIn: in std_logic ); --Serial input
end component ;
end mult_components;
but after compile show this error:
* Error: C:/modeltech64_10.5/examples/Multi_Player.vhd(132): Cannot drive signal 'Clk' of mode IN.
** Error: C:/modeltech64_10.5/examples/Multi_Player.vhd(136): Illegal target for signal assignment.
** Error: C:/modeltech64_10.5/examples/Multi_Player.vhd(136): (vcom-1136) Unknown identifier "Multiplier".
** Error: C:/modeltech64_10.5/examples/Multi_Player.vhd(138): Illegal target for signal assignment.
** Error: C:/modeltech64_10.5/examples/Multi_Player.vhd(138): (vcom-1136) Unknown identifier "Multiplicand".
** Error: C:/modeltech64_10.5/examples/Multi_Player.vhd(139): Cannot drive signal 'Start' of mode IN.
** Error: C:/modeltech64_10.5/examples/Multi_Player.vhd(141): Cannot read output "Done".
** Error: C:/modeltech64_10.5/examples/Multi_Player.vhd(142): (vcom-1136) Unknown identifier "Product".
** Error: C:/modeltech64_10.5/examples/Multi_Player.vhd(142): near "?": (vcom-1576) expecting ';'.
** Error: C:/modeltech64_10.5/examples/Multi_Player.vhd(148): VHDL Compiler exiting
what can i do?
please help me!
thanks.
Heres the problem:
You appear to have testbench code inside an entity. A testbench needs to be its own entity.
thanks but i wrote test bench:
library IEEE;
entity test is MultTop
end;
architecture btest of test is
begin
process
begin
wait for 50 ns;
assert (to_integer(UNSIGNED(Product)) = (i * j)) ? Check Product
wait for 50 ns;
end loop;
end loop;
end process;
end btest;
but give this error:
near "MultTop": (vcom-1576) expecting END.
It's only the first of many VHDL syntax errors. You should write
entity test is end;
But you still need to declare signals in the architecture before assigning values to it. And a testbench is useless without driving a design under test.
If you don't like to read a text book or tutorial before writing code, you can still debug your attempts line by line. Review the first error line, compare with VHDL language reference, correct, compile again. Repeat until compiled with no errors. Then try to simulate.
There are by the way code tags (# button under go advanced) to format your code appropriately and make it better readable. And the question should be surely posted in the Coding/VHDL rather than General Altera Discussion section.
