21615 Discussions
mux warning "Clock multiplexers are found and protected"
I implemented a simple mux like this
always @ (sel or in1 or in2 or in3 or in4) begin case(sel) 2'b00 : out = in1; 2'b01 : out = in2; 2'b10 : out = in3; default : out = in4; endcase end
Is working as supposed to, but Quartus gives me this warning:
Warning: Clock multiplexers are found and protected
Warning: Found clock multiplexer inmux:inst6|Mux0
What is this and how (should I?) modify code to avoid?
Thanks in advance,
As a general tip, if you want more information on a warning or error in Quartus, just right click on the error or warning and click help.
I don't hink you need to do anything unless you have a reason to. Quartus is just telling you that it did in fact recognize your multiplexer.
Read the HDL coding guidelines for multi-plexers beginning on page 6-61 of this document:
http://www.altera.com/literature/hb/qts/qts_qii51007.pdf
Jake
thank you!
