nios error
**** Build of configuration Debug for project hello_world_12 ****
make -s all includes
Linking hello_world_12.elf...
/cygdrive/c/altera/90/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: region onchip_memory2_0 is full (hello_world_12.elf section .text). Region needs to be 26004 bytes larger.
/cygdrive/c/altera/90/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .rodata [00008020 -> 00008507] overlaps section .exceptions [00008020 -> 000081c7]
/cygdrive/c/altera/90/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .rwdata [00008508 -> 00009f33] overlaps section .text [000081c8 -> 00013593]
/cygdrive/c/altera/90/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .bss [00009f34 -> 0000a147] overlaps section .text [000081c8 -> 00013593]
collect2: ld returned 1 exit status
make: *** [hello_world_12.elf] Error 1
Build completed in 1.875 seconds
You won't build that project to run in less that about 80k it pulls in far too much library code from libc.
There is a smaller example, but none of the Altera examples are really small.
Hi, you don't have enough memory on your board.
