21611 Discussions
HPS+PCIe project(Quartus II 13.1 64 bit),compile design--Assembler error
Info: *******************************************************************
Info: Running Quartus II 64-Bit Assembler
Info: Version 13.1.0 Build 162 10/23/2013 SJ Full Version
Info: Processing started: Thu Jan 09 10:46:06 2014
Info: Command: quartus_asm --read_settings_files=off --write_settings_files=off kz -c kz
Warning (15104): Quartus II software detected a bonding design. Reconfiguration is not supported for Bonded designs and MIF is not created for this design.
Info (115030): Assembler is generating device programming files
Error (210006): Can't save or open file D:/work/altera_pcie_hip_ast_ed/kz_cv/db/ip/pcie_de_gen1_x4_ast64_hps/submodules/sequencer/alt_types.pre.h
Error: Quartus II 64-Bit Assembler was unsuccessful. 1 error, 4 warnings
Error: Peak virtual memory: 706 megabytes
Error: Processing ended: Thu Jan 09 10:46:25 2014
Error: Elapsed time: 00:00:19
Error: Total CPU time (on all processors): 00:00:18
Error (293001): Quartus II Full Compilation was unsuccessful. 3 errors, 791 warnings
screenshots:
http://www.alteraforum.com.cn/attachment.aspx?attachmentid=1377
http://www.alteraforum.com.cn/attachment.aspx?attachmentid=1378
The alt_types.pre.h file is exist.
Anyone any suggestions on how to solve the problem ?
PS:
alt_types.pre.h file;
#ifndef __alt_types_h__
#define __alt_types_h__
* don't declare these typedefs if this file is included by assembly source.
#ifndef alt_asm_src
typedef signed char alt_8;
typedef unsigned char alt_u8;
typedef signed short alt_16;
typedef unsigned short alt_u16;
typedef signed long alt_32;
typedef unsigned long alt_u32;
typedef long long alt_64;
typedef unsigned long long alt_u64;
#endif
#define alt_inline __inline__
#define alt_always_inline __attribute__ ((always_inline))
#define alt_weak __attribute__((weak))
#endif /* __alt_types_h__ */
Did you get a resolution to this problem? I'm getting the same problem on 13.1.0 Build 162 Full Version
Dave
Found the issue - in the Project... Settings... Libraries the paths need to be added (they were automatically filled in in one of my projects, but not on the other) - not sure which one is needed (or maybe both) for the Project\db... and Project\QSysProject\synthesis...
c:\projects\dvlc5\fpga\db\ip\qsyscoresystem
c:\projects\dvlc5\fpga\db\ip\qsyscoresystem\submodules
c:\projects\dvlc5\fpga\db\ip\qsyscoresystem\submodules\sequencer
c:\projects\dvlc5\fpga\qsyscoresystem\synthesis
c:\projects\dvlc5\fpga\qsyscoresystem\synthesis\submodules
c:\projects\dvlc5\fpga\qsyscoresystem\synthesis\submodules\sequencer
--- Quote Start ---
screenshots:
PS:
#ifndef alt_asm_src
#endif
--- Quote End ---
The issue for me at least is that I was using the *.qsys file in my file list. Apparently you should instead use the *.qjp file from within the generated system hierarchy in the synthesis directory: pcie_de_gen1_x4_ast64_hps/synthesis/pcie_de_gen1_x4_ast64_hps.qjp
